NI TestStand
VI not opening! while step into (f8) during debugging in TestStand
Hello Every one,
I am new to TestStand, while debugging sequence steps in TestStand, I kept a breakpoint before a step. Then I started executing the sequence, the execution pauses at break point, but when I click on step into or F8 the respective step related VI front panel is not opening to debug. Kindly help me to fix this problem.
Thanks in advance
(2,069 Views)
Accepted by Krishnaarjuna
Hello
Please verify the Labview adapter is in Labview development system  (not run time engine)
(1,973 Views)
Thank you fcode111. your solution helped me to solve the problem.
(1,962 Views)
