NI TestStand
Value in sequence context in for "TestStand- Iniitalize Termination monitor.vi"
Which is the value in sequence context in for no error ??
(3,522 Views)
Accepted by Oriol.Bofill
Hello Oriol,
The “Sequence Context In” specifies an ActiveX reference to the TestStand SequenceContext object that you have to pass as a parameter in the VI called from TestStand. This object is the “ThisContext” element you have in the TestStand Variable Window.
This is an easy but nice example:
http://zone.ni.com/devzone/cda/epd/p/id/5838
(3,469 Views)
Thxs a lot sendia
(3,458 Views)
