What is TestStand "Ex Method"?
From time to time I see that some methods in TS has "Ex" suffix in the name. For example "PostUIMessageEx" or "EvaluateEx". What does that "Ex" mean?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(3,154 Views)
Accepted by bienieck
My understanding is that it stands for extended.  They created the Ex functions so as not to break backwards compatibility with previous versions.  So basically they added functionality or changed the prototype but they wanted existing code to port over without breaking the code.  In all cases you should use the Ex functions.  The non-Ex functions are obsolete.
Hope this helps,
jigg
CTA, CLA
testeract.com
(3,125 Views)
Appending "Ex" to method names if the call itself is changed (data type, number of parameters, etc.) is common for ActiveX. As Jigg says correctly, it is done to not break backward compatibility.
You can find this approach also in the ActiveX interface from many Microsoft products like Office tools.
Norbert
Expert: Geometry
(3,118 Views)
