NI TestStand
What is the best way to use TestStand/Labview to access database?
Is it best to use the TestStand database step types or use existing Labview database connectivity code to access database?
The database will contain configuration data and results data. I am also not using the standard results collection feature. (Test procedure will possibly last days so I think it is inappropriate to use results collection feature.)
I'm just trying to make my code "future proof".
(3,139 Views)
I have used both and I find that it is easier to use the Labview Database Connectivity Toolset. One step in a TestStand sequence can call the Labview vi. If done in TestStand, it takes many steps which I find harder to read and understand compared to Labview code. If it is just a simple one time access, TestStand may be a little easier, depends on one's preference.
- tbob
Inventor of the WORM Global
(3,138 Views)
Thanks.
I was thinking it would be easier to use the Labview code. I was just trying to sense if the community thought it was old hat and I should be using the TestStand code.
(3,125 Views)
