NI TestStand
Where can I define the location of my custom frontendcallbacks.seq file?
I have made some changes to my frontendcallbacks.seq file and I would like to place the custom file in a new location. I cannot find where the path is defined.
Toby
(3,937 Views)
Toby,
You didn't say which version you are using, but if its 4.1 then you can put your frontendcallbacks.seq in the Components\Callbacks\FrontEnd of the TestStand Publics area.
If it's any other version then in the <TestStand>\Components\User\Callbacks\Frontend folder.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,935 Views)
Sorry...I am using 4.1 on Vista. I realize I can put it in the public directory and that works great. I'm wondering if I am able to put it somewhere other than the public directory and then point TS to it? If I can't it's not a show stopper, but it would simplify my life a bit.
-Toby
(3,933 Views)
Accepted by TobyD
This is not possible at the current time.
Allen P.
NI
(3,929 Views)
OK. Thanks for you help Ray and Allen - at least I know I'm not crazy Smiley Very Happy
(3,924 Views)
Hi Allen,
Are you and NI dealing with such a feature in future releases ?
If this is possible all TS machines in the production field could access via Network file drive
the same frontendcallback file. So an updating would be more sufficient.
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,885 Views)
It is possible to change the public directory to a network path or another local path by changing a registry key.  Read: How to Configure a Custom Public Directory for TestStand 4.1 and Later knowledge base article.  Link: http://digital.ni.com/public.nsf/allkb/42A0D8B0DCEC64FE8625744F007F3A6D
(3,872 Views)
