NI TestStand
Where to change test limit
A board we test has 17 subseqs in its sequence file. In one of those 17, two Verify statements need to have different limits for a different version of the board. Right now the limits are hard coded numbers under the Limits tab for the two Verify statements. Are there some standard idioms  or rules of thumb for how to go about making readings like this flexible?
thanx,
jvh
(3,146 Views)
Accepted by jvh75021
How flexible do you want it? If you don't mind editing the sequence to keep up with new models, you can the limits by writing them to local variables with a couple of precconditions. There is the property loader and you can read the limits using that. This is the approach that I will eventually take - whenever we can get everyone to agree on the database design.
(3,140 Views)
Property Loader, that's it! Did not yet know of that step type.
Now I owe ya twice.
Thanks again.
jvh
(3,134 Views)
