Why is sequence "Passed" if a step inside is "Error"?
i have a simple testplan with only one sequence that contains only one labview-teststep.
The only thing that the step is doing is to create an error by passing a True to the Step.Result.Error.
When i only run this step then the "RunTimeError" pops up a window. There i click on OK and then the step is shown as "Error" in Status-column.
When i execute the sub-sequence that contains only this step then i also get the "RunTimeError"-window but now the sequence is shown as "Passed".
Why does this happen? Is this the normal teststand-behaviour?
Thanks for all help
(3,447 Views)
I created a sequence call to a sub-sequence containing a single step, a "none" adapter containing "Step.Result.Error.Occurred" in the pre-expression. The sequence call failed. I'm not sure if I'm re-creating the problem correctly?
Main
Call a Sequence   --->      Action(Step.Result.Error.Occurred=True)
Call a sequence shows failed
(3,445 Views)
Accepted by OnlyOne
No, I would not expect that behavior, unless you clicked to 'Ignore' the error on the RunTime Dialog.
When the 'Run Time Error' dialog appeared what Radio Button did you select?  See Attachment
PH
(3,431 Views)
Thats it. Somehow the Ignore-Button was selected...
Thx
(3,427 Views)
