NI TestStand
comment
Is there a way to insert a comment betwween steps/actions in Teststand 4.2?
(3,862 Views)
Accepted by topic author clint100
Use a label.  If you want it to look more like a comment, you can set the icon to blank.
GCentral
(3,856 Views)
Thanks..I saw that after I posted.  Any idea if you can chg the font size or style in the label?
(3,853 Views)
I don't think there are any settings directly on the step, but you could create a custom "Step List Configuration" that looks for steps of the label step type and changes the color or font setting based on that.
-Doug
(3,839 Views)
Thanks Doug
(3,834 Views)
Hi clint100,
As far as I can tell you can't change it. You can however try to accomplish it by using a custom step type that has a larger font. I hope that this helps.
Perry S.
Applications Engineer
(3,829 Views)
Thanks...that was suggested earlier too.  Guess thats the way to go.
(3,823 Views)
