NI TestStand
customize On the fly report generation
Hi Cheknom,
This sounds likely an error that occurs whenever you attempt to operate on a protected file.  You can find the details of this issue as well as the solution here.  If this isn't the case then if you could expand on exactly what you are doing when this error occurs and, if you could, the step that it occurs in.  This information would help debug the error that you are seeing.
Trey C.
Message 11 of 11
(752 Views)
