NI TestStand
deploying teststandV3 - dcom98 error on target
Ray,
I read over the log, unfortunately it doesn't list which directory is causing the error! I think we need to try to reproduce it here.
-Rick Francis
Message 11 of 15
(1,463 Views)
Ray,
The only way I was able to reproduce the problem was by running the Template MSI directly. When I copied it to the Deployment Utility folder and built a deployment, I was able to install on the Windows 98 Machine.
Allen P
NI
Message 12 of 15
(1,449 Views)
Hi Rick,
Just re-read your initial answer to Rash.
Just to confirm, the file 'DKTemplateEN.msi' has to be placed in TestStand\Components\NI\Tools\Deployment Utility\distkit\redist before the building of the installer?
During the creation of the installer is 'DKTemplateEN.msi' modified?
Regards
Ray Farmer
Regards
Ray Farmer
Message 13 of 15
(1,442 Views)
Ray,
>Just to confirm, the file 'DKTemplateEN.msi' has to be placed in >TestStand\Components\NI\Tools\Deployment Utility\distkit\redist before the building of the installer?
Yes that is correct.
Yes, DKTemplateEN.msi is a template for the installer. It will not designed to be runnable without the deployment utility processing it. During the processing the deployment utility will add your test files and possibly the TestStand engine to the installer.
-Rick Francis
Message 14 of 15
(1,436 Views)
That's where I am going wrong, I just copied it after generating installer files.
I'll do it properly this time and let you know the result, which will probably ok.
Cheers
Ray Farmer
Regards
Ray Farmer
Message 15 of 15
(1,424 Views)
