NI TestStand
dialog box title bar
Hello;
I am working with TestStand 2016.  I would like to make the dialog box title bar invisible (in the deployed version).  I am trying to limit what the operators see, and choices they can make.
Thanks in advance.
Michael C. Nedrow
(2,477 Views)
Accepted by mcnedrow
Hi Michael,
Not sure if that is possible if you are using the TestStand Message Popup.  You can remove the text in the title bar (set Step.TitleExpr to "").  You could create your own dialog (in LabVIEW or similar) and call that instead, then you would have a full back stage pass to display exactly what you want.
(2,469 Views)
