NI TestStand
disable print in simple OI
I have TestSTAND 4.1 and LV 8.6
I am using Testexec simple OI  after the sequence run to completion and after the banner PASS/FAIL, there is a pop up
with two button Start a new run or STOP.
if the operator press STOP, I use simple text report, the program will display the report with two buttons,
VIEW or Print the report.
How do I disable/ghost/grey the VIEW and (&&) PRINT button, because we already implement our own report printing feature?
regards
(3,229 Views)
Accepted by trout00
I don't believe you can grey-out the buttons, but you can remove them from the panel. If you open the actual top-level VI (not the executable), you can right-click on the report viewer and select ReportView » Properties. In the General tab, you can select which ToolBar buttons are shown. Uncheck the Viewer and Print buttons to disable those particular buttons.
(3,213 Views)
