NI TestStand
getting all help files for teststand
I was using TestStand "help" to get information on a property that a coworker of mine recommended that I look at, and the search returned "no topics found".  My coworker ran the same search (verified spelling and settings were the same) and he got 4-5 topics.  Is there a way to check if I have all of the up to date help documents/resources and if I don't how can I upgrade?
(4,396 Views)
Hey Jim,
You could try doing a repair install of TestStand, or modify the installation and make sure Documentation is selected to be installed in the features list. To perform these actions, go to Control Panel > Programs and Features, find National Instruments Software in the list, and double-click it. From there, you will be able to find NI TestStand, and either modify or repair the installation.
(4,390 Views)
Accepted by Jim1979
If you are using TestStand 2012, please upgrade to TestStand 2012 SP1, which corrects the search issue in the help system. You can also access the TestStand 2012 help on ni.com.
-Callie Jones
TestStand Documentation Team
(4,369 Views)
That worked.
(4,356 Views)
