how do i type spaces in DOS path names using cmd via call executable
TestStand 4.1 using call executable to call cmd with the argument expression (slightly edited)
"/C atprogram ... --verify -f C:\\test\\my folder\\map.hex > C:\\TEMP\\result.txt"
I can't use more quotes around "my folder" and my^ folder isn't accepted by atprogram.
Cheers,
(5,093 Views)
can you use single quotes?  Or is that a no go as well for that program?
jigg
CTA, CLA
testeract.com
(5,091 Views)
Accepted by Drash
Hi
To enter a " in the arguments text box you have to enter \" instead:
your string should look like that:
"/C atprogram ... --verify -f \"C:\\test\\my folder\\map.hex\" > C:\\TEMP\\result.txt"
Hope that helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,075 Views)
I tried single quotes but no joy I'm afraid.  Thanks for the suggestion though.
(5,067 Views)
Many thanks Juergen! I was scratching my head for longer than I'd like to admit on that one.
(5,064 Views)
