how to change a step name in subsequence
i am using the below statement to change the step name in subsequence. under pre expressions :
Step.name = RunState.SequenceFile.Data.Seq["MainSequence"].Main[Step.UniqueStepId].name + " [Channel: " + Locals.currentChannel + " | Iteration:" + Str(Locals.i) + "]"
I can able to execute the abouve statement in main sequence but not in subsequence. does anyone know how to change the step name of subsequence programmatically.
swathi kamble
(3,645 Views)
Locals of Main sequence cannot be used in Sub Sequence (Local Variables are used within a sequence not between sequences.make sure you are suing parameters if you need to share data between Sequences.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,596 Views)
Hello, Thanks for the reply. I used the file global to pass data between the sequence but still i am getting the error ( refer to the attached screen shot).
(3,590 Views)
Hello Swasa
If Possible Share the Sequence Which you have created.so that we can view and suggest you the right approach.
(3,574 Views)
In the main sequence i am calling call 4 up sub sequence, attached screenshot, In cal 4up seq on the 1 st step, i wanted to change the step name based on the for loop.
(3,563 Views)
Accepted by swasa
Step.Name = RunState.SequenceFile.Data.Seq[RunState.Sequence.Name].Main[Step.UniqueStepId].Name + " [Channel: " + FileGlobals.currentChannel + " | Iteration:" + Str(FileGlobals.i) + "]"
Hope this helps,
jigg
CTA, CLA
testeract.com
(3,553 Views)
Thank you!! It worked 🙂
(3,535 Views)
