how to set sequence file in Simple TestStand IO
Hello All,
Everytime I run the Simple IO - Top Level.vi, it loads the last run sequence file.  How do I default it to certain sequence?
Great appreciate for your help.
-Kenny
(3,397 Views)
Accepted by fatmonk
You can use the open sequence file method on the application manager (then you only need to wire the file path)
Rodéric L
Certified LabVIEW Architect
(3,393 Views)
You might also need to set ApplicationMgr.ReloadSequenceFilesOnStart to ReloadFile_None before the call to ApplicationMgr.Start
(3,379 Views)
thanks
(3,362 Views)
