11-11-2008 10:20 AM
TestStand v 2.0.1f1
There seems to be limit to the number of properties that can be loader for a single step using the property loader. I'm using an Excel sheet to identify my properties and I've been told before but no one could tell me the number of properties that can and can't be loaded. It's my understanding after the threshold is met the remaining properties are disregarded. If anyone knows please let me know. Thanks.
11-13-2008 11:20 AM
Hi Grasshopper,
This threshold does not seem to be documented anywhere, and I've never seen properties disregarded when using the Property Loader. What has been your experience? Can you give a ballpark number of properties where you start seeing properties disregarded?
11-17-2008 05:27 PM
11-18-2008 04:53 AM
I'm not sure if TestStand would disregard properties that it exported. I'm using TestStand 4.1 and i have succefully loaded as much as 150 properties.
Does TestStand give any error while running the propertyloader step ?
12-03-2012 11:25 AM
No error, the values just aren't loaded. This has been "fixed" by having multiple loader steps with different ranges. I.e. loader step 1 loads comp, high, and low for 15 limits specified as 0-14, loader step 2 loads comp, high, and low for 15 limits specified as 15-29, etc.
