query "is this sequence the process model client?" within the sequence?
I want to conditionally execute a step based on whether the currently executing sequence is the process model client.  Is there a boolean property somewhere I can query?  I see a "processmodelclient" container, in which I can compare the currently executing sequence path with the process model client path contained in this, but when I execute the sequence standalone (using "run mainsequence" from the execute menu), I get an error in the expression as there is no "runstate" in this circumstance.
David J.
(2,254 Views)
Accepted by david_jenkinson
The ProcessModelClient object only exists if the execution was initiated through a process model entry point. So, what about this for a boolean expression?
RunState.Exists("ProcessModelClient",0)
Hope this helps!
Trent
(2,247 Views)
