read sequence file properties from the test sequence
I use the old version of TestStand 2.1. I have the option of version sequence (Sequence File Properties) that incrimante each backup. I wanted to know if I can get in the sequence, a variable that indicates the version of the current program.
Thank you in advance
(3,961 Views)
Accepted by fishingman
If I understood your question correctly, either use ActiveX steps to access the PropertyObjectFile.Version property or use the hidden property: RunState.SequenceFile.Data.Version. Hidden properties are subject to change in future versions of TestStand though, so it's more future proof to use the API. This particular property has however never changed so far.
Hope this helps,
-Doug
(3,947 Views)
Thanks for your solution
(3,931 Views)
