remove characters from string
I'm currently in the process of developing a seqence for barcode parsing , then writing specific data from the barcode to EE on the UUT.     Here's my issue:  One particular character sting from the barcode contains several "-" marks. The the raw barcode data is as follows "aaaa-bbbb-cccc-dddd-eeee".    However, to write the data to EE, I need the sting in the following format:  "aaaabbbbccccddddeeee".   Is it possible to use Testand to revome the any instance of "-" from the sting?
(9,254 Views)
SearchAndReplace("aaaa-bbbb-cccc-dddd", "-", "", 0, False, -1, False)
jigg
CTA, CLA
testeract.com
(9,252 Views)
Accepted by svacek
Here's one option:
SearchAndReplace(Locals.InputString,"-","")
(9,250 Views)
Perfect!  Thanks for the asistance.
(9,247 Views)
How can i remove a "tab" from a string? i've tries the search and replace function, but it is not working for me.
(5,180 Views)
This worked for me: SearchAndReplace(Locals.VariableWithTabs, "\t", "")
It both modifies the variable and returns the modified value as the result of the function.
(5,177 Views)
