NI TestStand
set key focus
Using TS 2016, Message Popup, Enable Response Text Box, I don't see where to set the Key Focus to the Response Text Box instead of the default OK button. I want the text to be selected when the popup is run.
(2,335 Views)
Accepted by richjoh
You need to set the active control.  This page shows you how:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Wy5SAE&l=en-US
(2,318 Views)
