setup database dynamically
Hi Markus,
scrub that idea, it didnt work.
one thing I have noticed, when the execution is closed then the database is released. You dont have to exit TestStand or close the sequencefile.
Regards
Ray
Regards
Ray Farmer
Message 11 of 13
(1,313 Views)
Hi all,
I think now that there is now easy solution to change the database within the UUT loop. You have to modify DBLog.dll to add an additional method for closing/resetting  the used database to achieve that. And that's outside my time and knowledge ressources. I'll have to  live with the workaround to provide an extra sequence for each database.
Message 12 of 13
(1,303 Views)
The DBLog server adds a reference for the database connection to the execution and it is based on the name of he schema.  For example, look for a property named something like: "RunState.Execution.TSDatabaseLoggingDatalinkGeneric_Recordset__NI_". If you are running a single execution, I think that all that you need to do is release this property, i.e. set it to Nothing before starting the next loop.
Scott Richardson
https://testeract.com
Message 13 of 13
(1,296 Views)
