NI TestStand
stopping labview loop when terminating teststand
If I have a labview step which is called from teststand, which is in a loop, what property can I query (or does one exist), where I can conditionally exit my labview loop when the "terminate" button is pushed in teststand?  I see there are "termination monitor" tools in the teststand palatte in labview, but the "terminating" boolean does not go true when I initiate the terminate in teststand.  I have a simple test vi set up to test it, does not seem to function this way.
David J.
(3,178 Views)
Accepted by david_jenkinson
David
see attached example with TS 2010 and LV 2011. It shows how to use Termination Monitor and how to use LV modules to close asynchronuously running VIs.
Norbert
Norbert
Expert: Geometry
(3,172 Views)
