NI VeriStand Add-Ons Discussions
Modbus Custom Device Feedback
I found a 2015 version on GITHUB.  I seem to have a corrupt/missing RT Build Specification for the ModbusPharLap project (ModbusPharLap.lvlibp).  I can build another lvlibp, but I don't know what to set the properties as.  Can you help out?
Also after digging into the code I see this is for pharlap RT.  I need to build another project on the Linux CRIO, any ideas where to start with that?
Thanks!
Message 31 of 39
(7,225 Views)
Hi Joshe,
There is nothing yet for Linux-Based targets (32 and 64 Bits) because they didn't exist when the custom-device was first built.
So, the process is to create the .lvlibp for each OS and rebuild the CD.
About corrupted/missing Build Specs., can you send me a private message with some error code/screeen capture?
Regards
Vincent
Message 32 of 39
(7,225 Views)
Hi Vincent_R, I noticed that "Write Single Holding Register" is supported from version 2014.1.2 but there is no build of this version and newer (2015.1.4). Could you kindly compile a build and upload it? I need this item to use with a cRIO-9082. Thank you. MP
Message 33 of 39
(7,110 Views)
Hi Vincent_R,
First, thanks for your developement.
I need to build the custom device for a linux 64 target.
Can you tell me what i need to modify on the pharlap llb to use it on a linux 64 target please ?
Mickaël
Message 34 of 39
(6,892 Views)
Hi Vincent,
What exactely does it mean 56 in "Slave - Last Error Code" in a serial RTU Modbus communication on cRio-9082?
This error is always on time after time, I can  see it by "Slave - Last Error Code System-Time".
Any help?
Thank you.
MP
Message 35 of 39
(6,884 Views)
Hey Vincent,
I'm trying to get this Custom Device working in VeriStand 2016.  I have followed the instructions for opening and re-building in LV2016, but I'm still seeing the Page Error that RasmusVistisen described previously.  I can confirm that it seems to be due to the .NET dll not being found.  When I tried to run the sub-VI called "XML_Deserialize_XML_File.vi", I got error 1386.  Once I placed the dll in the project folder, this error went away.  Even though I'm able to execute this code through the LabVIEW source code, I still get the page error when I add the Modbus Custom Device in VeriStand.
Do I need to copy the "Modbus_CD_XML.dll" file to a different location so it can be found when called from VeriStand?
Message 36 of 39
(6,577 Views)
Has anyone succeeded in running this CD on a cRIO running Linux_X64?
I have a cRIO-9035 and am struggling to create a build that will deploy successfully.
So far I have created a VS2015.1 build for my PXI based system but am stuck on the next steps for the cRIO system.
Message 37 of 39
(6,142 Views)
I read the custom device can be instantiated only 2 times per target. Could someone tell me the reason of this limitation ?
Yohann L.
Message 38 of 39
(5,912 Views)
Can someone tell me what are the differences between https://github.com/NIVeriStandAdd-Ons/Modbus-Custom-Device and https://github.com/NIVeriStandAdd-Ons/Modbus-Custom-Device-v2 ?
Thanks a lot
Yohann L.
Message 39 of 39
(4,605 Views)
