NI VeriStand Add-Ons Discussions
Scan Engine & EtherCAT Custom Device Feedback
I've worked on this issue on and off for a few days before posting, but I finally found a workabe solution. The main cRIO chassis requires the use of U32 for DMA FIFO. The 9144 is using network shred variables. I changed the network shared variables from U32 to FXP 24bit word length -2bit integer work length. This passes the value as expectd into m veritand model.
Damian
Message 571 of 676
(1,496 Views)
Can you add support for NI 9437?
It's a new model supported now in EtherCAT 15.0
Thanks in advance!
Message 572 of 676
(1,496 Views)
I just recently upgraded to Veristand 2015 SP1 (from straight 2015 version), and now I appear to be having issues with the Scan Engine/EtherCAT custom device.  I cannot seem to deploy any system definition files that were created with the SP1 version and have the Scan Engine custom device configured.  I get the following error in the deployement log:  "The network operation exceeded the user specified or system time limit."
However, if I try to deploy a system definition file that was previously created on the straight 2015 version, the deployment is sucessful.  If I remove the configuration for the Scan Engine Custom Device, I can also sucessfully deploy a system def file created in VS 2015 SP1.
Do you know what might be causing this issue?
Thanks!
Message 573 of 676
(1,496 Views)
I also update Labview from 2015 to 2015 SP1...
I'm running the system definition on a CRIO-9081 with the following software:
Veristand Engine 2015.1.0
Ind. Comm for EtherCAT 15.0
NI-RIO 15.5
Labview RT 15.0.1
Message 574 of 676
(1,496 Views)
After upgrading from 2015 to 2015 SP1 we get the following error:
Error 74 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
Possible reason(s):
LabVIEW:  Memory or data structure corrupt.
NI VeriStand:  Unflatten From String in Server TCP Interface.lvlib:TCP Connection Manager.vi:7430001
Any idea for a solution?
Message 575 of 676
(1,496 Views)
Also having same problem with RasmusVistisen.
Shame to NI, for releasing a Veristand version that breaks compatibillity
Message 576 of 676
(1,496 Views)
Hi WhizzWr,
Sorry to read that. In order to help you, we need more information about the setup and conditions to reproduce issue.
  • Does it happen with an existing Sysdef and/or brand new one?
  • If you create a brand new Sysdef, add the Scan-Engine Custom Device, perform modules detection and deploy? Do you get the error?
  • What is your HW configuration?
If you cannot communicate all the details, send me a private message.
Best regards
Vincent RUAULT
Message 577 of 676
(1,496 Views)
Hi Vincent_R.
Actually I have a different setup (not Scan Engine & EtherCAT Custom Device Feedback)
I'll answer your question
  • Brand new project and sysdef, I tried the example (sinewave delay), empty project and sysdev. Same result
  • Unfortunately I do not have " Scan-Engine" in my custom device context menu, I only have "Embedded logger". Most likely because I do not have those setup in the first place
  • PXIe-8880 Embedded Controller on PXIe-1071 chassis. Veristand 2015 SP1.
Regards
W
Message 578 of 676
(1,496 Views)
Hi WhizzWr,
Thanks a lot for your quick reply. I have three questions/comments:
  • If you deploy on Windows (as NI-VS target) instead of PXIe-8880, does same error happen with a blank Sysdef and/or Sinewave example?
  • Did the Windows machine have NI-VS 2015 already installed before you installed NI-VS 2015 SP1?
  • Just to confirm, when you upgraded to NI-VS 2015 SP1, have-you upgraded the PXI RT Software (NI-VS Engine) as well?
I'm going to share that information with NI-VeriStand Support team. Can you send me a private message with your email address?
Best regards
Vincent
Message 579 of 676
(1,496 Views)
I just installed Veristand 2016 Scan Engine,  EtherCAT custom device - 2015 - v4.1.11, Industrial Comms 16.0, etc. Now I get a VI (too old) compatibility issue in System Eksplorer (sorry the "eks" character in my keyboard packed up:-) when I try to add the custom device to my system configuration.   Is this a known issue? If so, what is the workaround?  Thanks Richard
Message 580 of 676
(1,496 Views)
