10-06-2016 11:48 AM
Hey Vincent!
We have seen this on several different sets of hardware. All running NI VeriStand 2015 SP1. Setting the delay after load up to 10 seconds had no effect.
10-06-2016 11:58 AM
HI Vincent,
Here is a screen shot of the chassis in MAX. Everything works using this setup with the PXI-8231 as the Ethercat Master from LabView. It's only when I use it within Veristand that it causes a problem. The ScanEngine Custom device works fine when using a cRIO-9022 as the and Etheract master.
When the PXI-8231 is installed in the chassis, the deployment reaches the 'Stating Deployment group 1...' then throws the error I referenced above.
Stuart
10-12-2016 12:35 AM
I want to deploy a FMU model generated by Dymola into NI .I use FMI add-on file to veristand .but it fail when I deploy ,the error message show as below .
NI VeriStand Gateway.lvlib:VeriStand Server Wrapper.vi >> NI VeriStand Server.lvlib:NI VeriStand Server.vi >> Waveform Services.lvlib:Clear Active Streams.vi >> Server TCP Interface.lvlib:TCP Send Target System Command.vi:5680001 >> Server TCP Interface.lvlib:TCP Send Target Message.vi:890001
10-12-2016 07:32 AM
smurf1989,
I don't think this question belongs into this discussion thread as it doesn't seem to be related to Scan Engine & EtherCAT custom device. Please use the official VeriStand support channel -> http://sine.ni.com/psp/app/doc/p/id/psp-904/lang/en -> Ask an engineer
Andreas
10-12-2016 07:52 AM
Hi Stuart,
Could you send me the NI-VeriStand Project, please?
If you cannot post it on the forum, send it to me via a private message, please.
Regards
Vincent
10-12-2016 11:49 AM
To forum users,
We discussed that with Stuart (posts #587 and 591) and root cause was discovered. It was not related to that CD.
Regards
Vincent
10-13-2016 07:54 AM
Thank you !
fc1989123@163.com
Date: 2016-10-12 20:32
To: smurf1989
Subject: - Re: Scan Engine & EtherCAT Custom Device Feedback
created by Andreas Stark in NI VeriStand Add-Ons - View the full discussion
smurf1989,
Andreas
Reply to this message by replying to this email -or- go to the message on Community
Start a new discussion in NI VeriStand Add-Ons by email or at Community
11-30-2016 02:32 AM
with version 4.3 of the Scan Engine and EtherCAT custom device a support for 3rd Party EtherCAT Slaves is added.
What does this mean?
- Is it possibel to add 3rd party c-modules into the 9144 EtherCAT slave chassis?
- Is it possible to add 3rd party EtherCAT slaves like the Beckhoff EK1100 EtherCAT coupler?
Thanks.
Schragner
11-30-2016 09:05 AM
I have three simulator setups that are using the custom device. I have a PXI chassis with a Pharlap realtime controller. On one of the simulators I am able to run the project and get data from the input cards in the three 9144 etherCAT chassis and create outputs on the output cards. But I can not revert them to scan mode or load a new FPGA file. It gives the error that is attached. It is error 132465, Master 0 not found. On the other two simulators running the same project and having the same custom device files in the NI VeriStand folder I am able to reconfigure the FPGA on the three chasis. I am running VeriStand 2015 SP1.
12-01-2016 11:55 AM
Hello all,
It seems like the link for to download the latest custom device is offline.
Feel free to try:
NI VeriStand 2016 with NI-RIO 16.0+ and EtherCAT 16.0+:
Scan Engine and EtherCAT 2016 v4.3
Kind Regards,
Thierry
