03-22-2016 10:07 PM
I've worked on this issue on and off for a few days before posting, but I finally found a workabe solution. The main cRIO chassis requires the use of U32 for DMA FIFO. The 9144 is using network shred variables. I changed the network shared variables from U32 to FXP 24bit word length -2bit integer work length. This passes the value as expectd into m veritand model.
05-16-2016 08:11 AM
Can you add support for NI 9437?
It's a new model supported now in EtherCAT 15.0
Thanks in advance!
06-16-2016 04:21 PM
I just recently upgraded to Veristand 2015 SP1 (from straight 2015 version), and now I appear to be having issues with the Scan Engine/EtherCAT custom device. I cannot seem to deploy any system definition files that were created with the SP1 version and have the Scan Engine custom device configured. I get the following error in the deployement log: "The network operation exceeded the user specified or system time limit."
However, if I try to deploy a system definition file that was previously created on the straight 2015 version, the deployment is sucessful. If I remove the configuration for the Scan Engine Custom Device, I can also sucessfully deploy a system def file created in VS 2015 SP1.
Do you know what might be causing this issue?
Thanks!
06-16-2016 04:28 PM
I also update Labview from 2015 to 2015 SP1...
I'm running the system definition on a CRIO-9081 with the following software:
Veristand Engine 2015.1.0
Ind. Comm for EtherCAT 15.0
NI-RIO 15.5
Labview RT 15.0.1
07-12-2016 01:34 AM
After upgrading from 2015 to 2015 SP1 we get the following error:
Error 74 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
Possible reason(s):
LabVIEW: Memory or data structure corrupt.
NI VeriStand: Unflatten From String in Server TCP Interface.lvlib:TCP Connection Manager.vi:7430001
Any idea for a solution?
07-22-2016 01:15 PM
Also having same problem with RasmusVistisen.
Shame to NI, for releasing a Veristand version that breaks compatibillity
07-22-2016 01:21 PM
Hi WhizzWr,
Sorry to read that. In order to help you, we need more information about the setup and conditions to reproduce issue.
If you cannot communicate all the details, send me a private message.
Best regards
Vincent RUAULT
07-25-2016 06:32 AM
Hi Vincent_R.
Actually I have a different setup (not Scan Engine & EtherCAT Custom Device Feedback)
I'll answer your question
Regards
W
07-25-2016 07:24 AM
Hi WhizzWr,
Thanks a lot for your quick reply. I have three questions/comments:
I'm going to share that information with NI-VeriStand Support team. Can you send me a private message with your email address?
Best regards
Vincent
08-11-2016 10:36 PM
I just installed Veristand 2016 Scan Engine, EtherCAT custom device - 2015 - v4.1.11, Industrial Comms 16.0, etc. Now I get a VI (too old) compatibility issue in System Eksplorer (sorry the "eks" character in my keyboard packed up:-) when I try to add the custom device to my system configuration. Is this a known issue? If so, what is the workaround? Thanks Richard
