NI VeriStand Add-Ons Discussions
Scan Engine & EtherCAT Custom Device Feedback
Yes, we had a ini key setup as described here:
https://decibel.ni.com/content/projects/ni-timesync-ni-sync-hardware-support
We can try to add everything else except the time sync and see if it is still stable (NI Switch, NI-XNET).
Message 291 of 676
(911 Views)
OK sounds like a good plan. I'll do the Sync stuff and we can meet in the middle.
Stephen B
Message 292 of 676
(911 Views)
Few more questions
1) What mode did you have the 6683 in? 1588 mode, GPS, default?
2) What time sync settings did you have configured on the "time settings" page in MAX?
3) What settings did you have for the Ethernet adapter?
Stephen B
Message 293 of 676
(911 Views)
Nevermind. Just reproduced!
Stephen B
Message 294 of 676
(911 Views)
I'm going to try uninstalling NI-TimeSync 1.2 and the NI-TimeSync Plugin for NI-Sync and seeing if the issue still reproduces. Once I have that narrowed down, I will work with R&D to find the root cause.
Stephen B
Message 295 of 676
(911 Views)
Just reproduced without NI-TimeSync and with NI-Sync
Stephen B
Message 296 of 676
(911 Views)
I'm glad to hear that you are able to reproduce that.
We run the system with everything except time sync and it is working stable (ca. 24h), so I think we now know which software is causing the problem.
Any idea how we can fix it? Or when we can expect some patch/fix from Your side?
Sorry that I'm pushing so much, but for our client it is a show stopper and we have some deadlines till end of August.
Message 297 of 676
(911 Views)
without NI-TimeSync, but with NI-Sync, it was not stable for me. So I believe the problem is with NI-Sync, not NI-TimeSync.
I'm working with R&D on the issue now. I cannot promise any time frame as we don't know the exact issue yet. Can you tell me your service request number and name of the support contact at your branch?
Stephen B
Message 298 of 676
(911 Views)
Nevermind I found it, SR 1444290
Stephen B
Message 299 of 676
(911 Views)
JeKo,
I've figured out a few things. With the NI-Sync card and driver installed, the EtherCAT read/write API calls sometimes return error -2147138393. The custom device catches this error and filters it out as a 'late count'. However, not before the error is internally passed through our Fixed Point UDV read/write code which will set the UDV reference to blank if it is passed an error. So next iteration, the custom device throws error -1950678941.
I've fixed the Fixed Point UDV read/write code to no longer set the UDV reference to blank if it was passed an error. Therefore, the system will not error shut down after seeing error -2147138393, it will simply count that iteration as 'late' as it is supposed to. This will allow you to run without shutting down.
I am posting a new version right now, 4.1.4, with this fix. However, this does not explain why we are getting error -2147138393 intermittently when NI-Sync is installed in the first place. Our R&D team is looking into that now.
Stephen B
Message 300 of 676
(911 Views)
