PXI
-1074126826 max time exceeded
Hello
I'm using a PXI-1024 mainframe with a mixi3 interface to a pc
In the mainframe is a PXI-4070 multimeter and a PXI-2503 multiplexer.
When I run the testprogramm in Teststand I get error "-1074126826: max time exceeded" from the PXI 2503.
When I run a selftest in MAX for the 4070 and the 2503, everything works fine.
Driver for PXI 4070 is version 2.5.0
Driver for PXI 2503 is version 2.20
OS is Windows XP
PC is HP Compac 7700p
I can not use newer drivers because I have to be compatible with Labwindows 6.0.
What is the error cause
thanks for your help in advance
Tonnie
Message 1 of 1
(3,132 Views)
