PXI
5451 2 channels arbitrary waveform
We wanted to generate two different arbitrary waveforms simultaneously using PXIe 5451.
To make the LabVIEW code, we created a FGEN Express vi and opened the Front Panel of that and observed that they have used the same Waveform Handle for both channels (image attached).
We tried to have separate waveform handles for individual channels and got some error.
Why should we do like this?
Srikanth
(3,487 Views)
Could you please elaborate more on the error that you encountered while you tried to use 2 different handles. Also if you could upload the VI, it would help us solve the issue fast.
Sagar G Yadav | Application Engineer | National Instruments
(3,467 Views)
