PXI
Are there any available vi's for PXI?
Are there any VI's avaliable for PXI as it is for example VXI?
Regards
Henrik
(3,161 Views)
Hi Henrik,
What kind of VI's do you need? PXI (PCI Extension for Instrumentation) is based on the PCI bus and you've usually a Windows PXI-Controller or a MXI-4 link (PCI-PCI-Bridge) which controls all boards in a PXI Chassis. There is no difference prgramming differnce between a LabVIEW VI which runs in a PC or in a PXI Controller. For example, it doesn't matter if you've a PCI-6025 DAQ board or a PXI-6025 board. The VI (programming) is the same. Of course, the PXI factor has more synchronisation and trigger capabilities then a PC based system, but there are no special VI's for that. The same DAQ driver handles both.
I can give you a more detailed answer if you can give more informations. What do you want to do?
Luca
(3,148 Views)
