PXI
Calibration
Hello everyvone,
i have a PXIe System with 5 modules and there are some AI which show for example ~1V althaugh there is no voltage on the Input.
I have already made the calibration at MAX.
What can i do now?
(2,335 Views)
Accepted by ache
Hello Ache,
why do you think, that there is no voltage, i.e. potential difference on the input? (I.e. why should be 0 V if you do not short the input?)
Actually, if you don't connect a signal-cable, the input will float, so there will be a voltage defined by oxide trapped charges, noise and the input circuitry itself.
So if you have doubts, how the AI-channel behaves in case of 0 V input, just short-circuit it.
Best Regards,
NI TSE
(2,303 Views)
i think you are right!
thank you very much!
Michael
(2,295 Views)
Hi Ache,
you're welcome!
Best Regards,
NI TSE
(2,289 Views)
