PXI
Can I export list of software intalled on PXI chassis through MAX
I am trying to export list of softwared installed on PXI chassis for archiving purposes via MAX. This way when i need to reinstall software on chassis i know exactly which drivers were used previously.
(4,347 Views)
Accepted by topic author drakkar
Hello drakkar,
You can create a NI Max report.  For this please go to File >> Create Report.  In here you can select for which system you want to create the report and the type of it.
Daniel M.
Applications Engineering
Daniel M.
www.ni.com/support
(4,333 Views)
That will work. Thanks!
(4,325 Views)
Hello drakkar,
Np, please mark the answer as a solution for your issue.
Daniel M.
www.ni.com/support
Daniel M.
www.ni.com/support
(4,323 Views)
