I haven't used the XML I/O feature since LabView 6i, I went looking for it today under the Floppy disk Icon and it wasn't there. Where has XML operations been moved to for LabView 8.5?
In 8.5 the XML VIs are actually under String. When in doubt, right-click the Block Diagram and click Search in the upper-right corner of the Functions Palette.
Brian A. National Instruments Applications Engineer
