‎02-16-2006 11:43 PM
‎02-17-2006 07:31 PM
‎02-19-2006 10:09 PM
‎02-20-2006 06:46 PM
‎02-20-2006 11:22 PM
‎02-20-2006 11:51 PM
‎02-21-2006 04:24 PM
The Windows function used in the Knowledgebase I referenced is only effective on Windows 9x systems, so if you are using a newer version of Windows, it won't work for you. Running LabVIEW as a service is really more of an OS question than a LabVIEW question, and I'm afriad I don't have any experience with this. LabVIEW can be treated like any other application when it comes to calling it as a service from C#, so I would try searching online for a solution. Perhaps if anyone else on the forums has experience with calling LabVIEW as a service on newer Windows versions, they can share their experiences.
Kind Regards,
‎12-01-2006 12:45 AM
‎12-04-2006 11:18 AM
‎12-04-2006 10:50 PM
Hiii, Michael
Actually these all suggetions are about to hide the normal exe file, but what i am asking is aobut any method in LabVIEW, which directly do the same thing and when i make the exe it always make it like when the LabVIEW exe runs, runs as the background process.
Nishant
