PXI
Compatibility with PXIe8135
I am a student in a laboratory and need to use a PXIe6345 for analogue inputs. The chassis controller is a PXIe8135 with an old operating system: 'NI Real-Time Phar Lap ETS 13.1'. The chassis is in TCP/IP with the computer. I need to be able to create tasks in MAX. On the computer the technician installed the new versions of MAX LabView etc.. but obviously it doesn't work and I get an error -88716. So I'm wondering what to do?
Thank you for your help
I put the reports below
(1,752 Views)
Accepted by topic author jadR
Error -88716 or Red 'X' on Real-Time (RT) Controller or DAQ Card in NI MAX
Your PXIe-8135 has LabVIEW Real-Time 14.0 installed but your host PC has LabVIEW 2023 Q3 installed.
At the same time, Pharlap is no longer supported for LabVIEW 2022 or later. You would need LabVIEW 2021 or earlier to continue using Pharlap 8135. (https://www.ni.com/content/dam/web/pdfs/phar-lap-rt-eol-roadmap.pdf)
https://tmesystems.net/
(1,729 Views)
