PXI
NI-DAQmx Driver Mismatch Linux RT Target
I'm having an issue deciphering where a mismatch in my DAQmx device drivers is occurring. I'm getting Error -88716 on all the cards installed on my 8880 running NI Linux RT x64 6.1.38-rt12. The DAQmx Device Driver version on the that system is 23.8.0f202. Unfortunately, there doesn't appear to be a version that matches that available for my host system (running Windows). NI Package Manager only breaks out DAQmx versions using the year/quarter nomenclature. I've tried installing 2023 Q4, 2023 Q3, and 2023 Q2 without success. Does anyone have any insight into how to map these versions together correctly? Thank you.
(3,744 Views)
Accepted by topic author wharwood
What is the version of the NI Linux RT System Image installed on the Linux RT PXI? It should match the DAQmx driver version on the host.
Based on the feed, seems like 23.8 is 2023 Q4.
What is the device model you are trying to control?
https://tmesystems.net/
(3,737 Views)
Good insight! I upgraded my system image to 2023 Q4 and that fixed the issue. Thank you!
(3,709 Views)
