PXI
Daisy chain two PXIe-1084 chassis controlled by a single host
Already have a single chassis being controlled by a host and want to connect a second chassis.  I have a PXIe-8381 (just found that 8381 does not support daisy chaining) card and a three meter copper cable PN 153803A-03.  So I need more help than I thought when I began writing this.
(215 Views)
Please list the Bus extension and Remote control cards you've at hand?
Expanding or Daisy Chaining Multiple PXIe or PXI Chassis - NI
Santhosh
Soliton Technologies
(204 Views)
I found the link you shared the PXIe-8360 is no longer sold and the PXIe-8381 (which I have) does not support daisy chaining.
PXIe-8381
FROM $ 2,653.00
Price may vary with addition of accessories and services.
Item details
Supported Cable Type: Copper
Supports Daisy Chaining: No
Bus Connector: -
MXI Communication Level: MXI-Express Gen2 x8
MXI Bandwidth: 4 GB/s
Number of MXI Ports: 1
(192 Views)
Accepted by RedSoxFan62
To daisy chain to another chassis, you'll need a bus expansion module. The bus expansion module that connects to the 8381 is the PXIe-8384. The 8384 will go in any peripherial slot of the master chassis and connect to the 8381 in the downstream chassis.
(182 Views)
If you don't have the slot for an 8384 (and want to spend more money 🙂 ) you can replace your existing PCIe-8381+PXIe-8384 with a PCIe-8398+PXIe-8398. Then you can either
  • star out to both chassis from the PCIe-8398
  • daisy-chain from the first PXIe-8398 to another PXIe-8398 in your 2nd chassis
- Robert
(180 Views)
Thanks I will probably go with this because I only need to purchase one card.  My employer blocks email messages telling me someone responded.
(141 Views)
