PXI
Determining Hardware/Channels from IVI Names
From a Switch Executive switch Group, how do you programmatically determine the Routes, the Routes' Channels, and the Channels' device/iviChan definition?
(3,027 Views)
TC99,
I found the following description for how to get a list of configured routes in Switch Exec:
Route list in Switch Executive
This interface may also allow you to get the other info you were after. Post here if this does not work out for you.
Sincerely,
Ross C
Applications Engineer
(3,027 Views)
