PXI
How do I configure and use a NI PCI-6509 digital IO card in labview realtime
I want to use a  NI-PCI-6509 digital IO card in my realtime target. The device is installed and accoridng to MAX it's working properly. How do I control it from labview,. I am running labview 8.5 RT and DAQ-MX 8.6
Tom
(4,793 Views)
Hi Tom,
You should be able to control your PCI-6509 board in LabVIEW using the normal DAQmx calls you use as if you were using a PC target.  To get started, try running any of the digital input or output DAQmx examples in the NI Example Finder.
Way S.
(4,634 Views)
Way,
I have managed to configure the card now. What I was missing was the appropiate parts of DAQ-mx for labview 8.5. When I installed DAQ-MX for some reason I didn't install the labview 8.5 runtime.
Tom
(4,630 Views)
Hi Tom,
LabVIEW Runtime 8.5 is part of the LabVIEW 8.5 installation and not a part of DAQmx. For real-time applications, you are probably talking about installing the LabVIEW Real-Time Engine and not the Runtime engine. Can you explain a little more about your setup? Are you using two desktop PCs, one as a development machine (running Windows) and the other as your RT target (running LabVIEW Real-Time ETS)? Have you followed the steps here to setup your RT target PC:
Let me know.
Way
(4,622 Views)
