PXI
I need to replace a PSU4112 with 4110 for supplying 24V/400mA
Is this possible?
Because 4110 has max of 20V, I would combine 2 channels of the 4110 to reach the 24V.
thx
(2,269 Views)
Accepted by kdCMC
The PXI‑4110 has two isolated and a single non-isolated supply channel, all capable of generating up to 1 A per channel. You can program the voltage setpoint and current limit as well as the voltage and current readback/measurement functionality. You can also combine channels for higher voltage or current.
Because channels 1 and 2 on the NI PXI-4110 are isolated outputs, you can cascade multiple channels in series to generate greater output voltage. For safety reasons, all the terminals must be <60 VDC from ground."
bhovhann
(2,207 Views)
