PXI
Is it possible to send data to an external SCSI HDD in RT Mode? (using PXI-8214 interface)
Hi
i just wanted to know if it's possible to use an external SCSI-HDD with the PXI-8214 Interface on a PXI-System in RT-Mode. I need to save lots of data (>100GB) on this HDD acquired by a RT-App.
thx
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(4,126 Views)
Sorry, but it's not possible to use SCSI HDD in RT Mode!
The only possibility is, to use a 1394pxi card and a 1394 drive...
(and you need the IEEE-1394 driver for HDDs)
regards,
Thomas Sandrisser
(4,116 Views)
thanks Thomas
my local NI-Distributer told me neither USB nor Firewire are supported under RT. Have you done that yourself? Would be great if so, cause that would solve some problems i got.
regards
chris
Best regards
chris
(4,116 Views)
Chris,
Thomas is correct. FireWire is supported under LabVIEW RT. The following tutorial details this topic:
NI-1394 External Drive Support [broken link removed]
Good luck with your application.
Spencer S.
(4,106 Views)
thx Thomas and Spencer,
that information helps a lot!
best regards
chris
Best regards
chris
(4,097 Views)
