‎08-10-2016 01:16 PM
Hi everybody,
I am using NI-RFSA 5663E.
Now I am trying to measure my signal by that reseiver but to get phase and magnitude not magnitude only. does any body know if that possible, because I couldn't find from where to set the front panel inorder to give me magnitude and phase.
note: using the receiver Front Panel of NI-MAX not by writting code because I've done that in my code.
Thank you
best regards
Thoalfukar
‎08-11-2016 10:37 AM
Hi Thoalfukar, why don't you want to do it within LabVIEW?
‎08-11-2016 10:41 AM
‎08-11-2016 11:15 AM
looks like you can't do that in MAX SFP, but you can use LV examples, especially RFSA acquire continuous IQ to get the code that is sure to work.
You can modify it slightly to get the phase data and verify your code.
