PXI
NI MAX NI-PXIe + NI MAX receiver front panel
Hi everybody,
I am using NI-RFSA 5663E.
Now  I am trying to measure my signal by that reseiver but to get phase and magnitude not magnitude only. does any body know if that possible, because I couldn't find from where to set the front panel inorder to give me magnitude and phase.
note: using the receiver Front Panel of NI-MAX not by writting code because I've done that in my code.
Thank you
best regards
Thoalfukar
(3,523 Views)
 Hi Thoalfukar, why don't you want to do it within LabVIEW?
Everything has an End, and you get to it only if you keep on
-E. Nesbit
(3,497 Views)
Because I want to verify the maths in my code. Some think related to the phase reference standard, I wanted to check weather it workes as I want or not.
Regards
Thoalfukar
(3,494 Views)
looks like you can't do that in MAX SFP, but you can use LV examples, especially RFSA acquire continuous IQ to get the code that is sure to work.
You can modify it slightly to get the phase data and verify your code.
-E. Nesbit
(3,491 Views)
