PXI
NI -PXIe-4143
Hi ,
I have a doubt , when I use Instrument Studio for NI-PXIe-4143 , when i keep the SMU in Idle state , how does it behave , is it a very high Impedance to Ground , or is it a finite ,say 100kohms to ground .I wanted to ask because i generally see current being sourced/sinked when i am keeping the Smu off only .
(2,237 Views)
Accepted by shiksri
4143 does not have an output relay, hence the internal circuit is always connected to the external circuit.
In your case, it will behave as Source 0V with a 2% current range as the current limit.
Given the SMU can source/sink up to 2% of the current range, your observation seems valid.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OQ0SAM&l=en-US
Santhosh
Soliton Technologies
(2,216 Views)
OK , and when it is Voltage mode , it behaves as a voltage source with approx zero internal resistance?
(2,164 Views)
