PXI
PXI-1033 Chassis is not recognized by MAX, using express card/Latitude D820 Laptop
I got a new PXI-1033 Chassis with an host Express Card that connects to a Dell Lattide D820 Laptop (that has the latest BIOS from Dell). A PXI-6542 resides on slot 2 of the chassis.
1) The Link led of the chassis is blinking red.
2) Both leds, Active and Access, in the PXI-6542 are OFF.
3) I have manually configure in MAX the controller as "External PC" and "PCI-1033 Embedded Controller", and the chassis as "NI PXI-1033"
4) The PXI-Cassis is always powered up before the Laptop is reboot.
The PXI-6542 is not shown in MAX.
Am I doing something wrong or one or more of my devices could be defective?
(3,732 Views)
Hello sanides,
I have a few questions for you.  Did you install the driver for the PXI-6542?  NI-HSDIO (the driver you need) can be found here.  Also, are there any other cards in the chassis?  And if so, are they detected in MAX?
Please get back to me so that I can help you further!
Meghan
(3,718 Views)
