PXI
looping through data delay values nihsdio
I am writing a program where I loop through different data delay values using the nihsdio. I get an error message that my data delay value cannot be configured. When I readjust data delay or any other configuration settings for generation and configuration do I have to close the nihsdio device completely and reinitialize everything or can I configure between aquisitions, and then close the device when I am finished.
Thank you,
(3,229 Views)
Hi Timothy -
You should be able to use the niHSDIO Commit VI to set a new value without having to Abort the session.  Are you using this function?  Also, which range of values are you trying to set?
David Staab, CLA
Staff Systems Engineer
(3,201 Views)
