PXI
PXI-5105 Re-Arm Time
I have a Lab-View GUI which is fetching data each time a User Interfacea Trigger level is exceed, the datasheet specified a minimum of 2.6us for Re-Arm.
This re-arm is true always or sotware add more delay to it.
How the Internal Memory on the Card itself works? Is a circular buffer saving data after the Re-Arm happen still if the sotware is processing the data?
(4,372 Views)
Hi Joel_Cruz,
You can find information about the Onboard Memeory for the PXI-5105 in the NI High-Speed Digitizers Help. This help file installs with the NI-Scope driver.
The specific information on the NI 5105 Onboard Memory can be found under NI High-Speed Digitizers Help>>Devices>>NI 5105>>Onboard Memory.
Regards
Carli S.
Troubleshooting & Maintenance Digital Business Manager - NI
(4,348 Views)
