PXI
PXI-8101 disk recovery
Hi All!
The disk of the  PXI-8101 controller seems to have crashed. When trying to load RT Safe mode, an error occurs:
Reliance v2.10 Build 1053: Assertion failure in module rlinode.c line 1138 (DCL=351)
The NI website recommends reformatting the drive. The problem is that I cannot find the Recovery CD. There is no image on the NI website either.
The Question is: Does anyone have a Recovery CD image?
Or maybe there is another way to restore the system?
Jury
(1,178 Views)
You can create the bootable USB using NI MAX.
Using a Utility USB Drive to Format my Real-Time Phar Lap ETS PXI Controller
https://tmesystems.net/
(1,166 Views)
Hi!
Thank you for answer!
I try to do this in NI-MAX 5.4. But this utility do not see USB drive:
"unable to detect USB drive". I try this with USB Flash as well as with HDD USB drive.
Windows work with this drive normally.
"Reset configuration data" do not resolve this problem.
Jury
(1,133 Views)
