HI,
I AM USING PXI 8186 RT CONTROLLER AND MAX IS SHOWING THAT PXI IS RUNNING IN SAFE MODE. ALSO I AM UNABLE TO RUN ANY PROGRAMS. MAX IS SHOWING ME AT THE BOTTOM RIGHT CORNER OF THE WINDOW AS PXI RT CONTROLLER STATUS AS CONNECTED (SOFTWARE ERROR).
WHAT IS THE REASON FOR THIS CASE.
I ACTUALLY UNINSTALLED THE SOFTWRAES FROM RT CONTROLLER AND THEN RE INSTALLED. THEN IT STARTS WORKING.
PLEASE EXPLAIN ME THE CONDITION IN WHICH THIS CASE WILL HAPPEN IN PXI RT CONTROLLERS.
THANKS,
M.VALLIAPPAN.
